VESC crashes on Servo output
AutonomousDrifting
AutonomousDrifting's picture
Hello everyone,
I have a VESC 6 MKV that I am trying to use to control a F1Tenth-type Autonomous RC-Car. I have flashed the VESC with the newest (servo_out enabled) Firmware (5.02). The motor and servo of the car are controlled over the VESC ROS driver (https://github.com/f1tenth/f1tenth_system/tree/master/vesc).
My problem is the following:
Adjusting (only) the throttle for the motor works fine. However, when I begin to steer (i.e. the VESC outputs a PWM signal to the servo) the VESC quickly (after 1-3 sec.) crashes. It blinks red and blue (reboots) and once it's rebooted, the steering still works, but the other motor does not move.
When using the default servo speed, that was successfully used with other servos, the ROS package outputs an OUT_OF_SYNC with VESC error and the above behavior occurs. This error has to do with the serial communication packets being not of expected size or content. When I move the steering joystick slower, or when I reduce the max. steering speed parameter in the code, there is no error thrown but the above behavior still occurs.
I have a "SRT CH6012 HV Low Profile" Servo, which is suited for 1:10 scale RC vehicles.
However, when I tried other servos, the above behavior did not occur. So might there be something wrong with the servo? It seems to work fine for a few seconds, so it is plugged in correctly. Shouldn't the VESC be able to handle common RC servos? Or is there something I am missing, like a totally different baud-rate of the servo or something?
Many Thanks in advance,
AutonomousDrifting
After crashing and rebooting, do you have a fault code from the vesc?
AutonomousDrifting
I am not sure. How would I know?
The ROS driver sometimes gives this "out-of-sync with vesc" error, only indicating that there is something wrong with the packets.
How do I obtain such a fault code?
EDIT: I have just checked again. The VESC does indeed return the fault code 3. Which seems to be "FAULT_CODE_DRV8302".
So there seems to be a problem with the DRV chip?
I have also noticed, that when I turn down the servo speed even more. The issue happens less and less often, at some point steering is unusably slow, but the error does not occur anymore.
Hoselebewesen1
Last seen: 5 years 1 week ago
I´m experiencing a similar behavior, do you fixed your problem yet? When I´m steering too fast the VESC crashes and turns off. After reboot it, everything works again. Hopefully you can help.
Sure you have no GND loops in the system and the VESC logic is galvanically isolated towards other devices? also you might drain to much power from the 5V rail.
monkey-man
Last seen: 5 months 24 min ago
I am experiencing the same problem with a 1:5 RC with the VESC connected to my computer. Here is my setup:
VESC MK6 running firmware 6.05
Powering the VESC with a 4S LiPO battery
Servo is "S900S 1/5 Scale Digital Metal Gear Servo"
Motor is "Dynamite 1/5th BL Motor 800kV"
I can reproduce the problem within VESC Tool UI. I send a constant RPM command to the motor (2000 RPM in the fault below). Then, I steer the servo from left to right pretty fast and then the motor stops and I have to reboot the VESC to be able to send another velocity commands. Here is the fault generated:
Fault : FAULT_CODE_DRV
Motor : 1
Current : 1.7
Current filtered : 3.3
Voltage : 16.71
Duty : 0.069
RPM : 1979.0
Tacho : 30754
Cycles running : 97741
TIM duty : 386
TIM val samp : 2800
TIM current samp : 2800
TIM top : 5600
Comm step : 0
Temperature : 29.67
DRV8301_FAULTS : No DRV8301 faults
In my ROS node, I tried to limit the servo min/max values as well as reducing the maximum angular speed of the servo as mentioned, but I can still crash the VESC by just alternating left/right fast
Any ideas?
Thanks in advance!
Onarb Kabr
V E S C T O O L P R O J E C T F O R
E V E R Y O N E®
(known as Pandora's box...)
Dear Mr. Vedder...(or somebody else)
I am "happy" owner of 100A vesc controller, one kilogram weight ,3.5kW outrunner and 66 pcs. of Li-Ion cells. I highly praise and admire Your masterwork called: VESC TOOL PROJECT...but...possession is not enough to be a Lucky guy. Goddess of Fortune won't smile on you .....until you get educated. And this is a core of my problem. I am standard electrician - electrician bu trade -maintenance guy .. with some Electronic experiences.. but... FOR PROPERLY SET/ADJUSTED VESC-(tool) it's NOT ENOUGH... THIS IS A TASK FOR NARROWLY SPECIALISED - UNIVERSITY EDUCATED EXPERT(S)-! engineers... How Can a guy/girl with medium education fully enjoy their devices which costs several hundreds $or€or£...? Problems which are fixed on vesc forum are not for ordinary folk... plenty of requirements...real QUANTUM of values...Questions seems endless.... So ... what is a solution - (for everyone) ? ...
My proposal is:
pleas ...
# Create (some possible) database (list) of verified-recomended-well estabilished settings of "vesc+mot"-pairs, which's "behavior" -based on (some) requirements will be (briefly) described in attached description. (batt.type too) if it's possible, "pack of settings" could be easy sent by email . Contrive and trump up the way how to transfer "pack of settings" get into vesctool and drop it in vesc.
# Make (affordable payed) service which will Create "custom settings" based on individual "unit behavior" requirements. (May offer limited list of settings of pairs - which's behavior and properties are REALLY and SERIOUSLY tried and approved)
# Make an "homepage post" - place, where satisfied users will publish (in prescribed way) their own settings-experiencies with their pairs (vesc+mot) with behavior-properties of used drive units...(boards, scooters, bikes,vehicles...) (those people could be called DIAMOND CONTRIBUTORS )
or
# Send me some website where I Can buy some cyanide or any venom....
truly Yours...
Hopeless Holder™
... Sent From my sister's Huawei
dawgs
Last seen: 10 months 1 day ago
Problem Solved. Same symptom and same configuration(f1tenth ros2) but not sure it will fix yours.
1. Symptom: While start steering, red led flashes 3 times then motor cannot move.
2. Recovery action: VESC Power cycle or Reboot
3. Hypothesis: SERVO HW Error (I did so many things to find this.)
 - SERVO Power is not enough for extra load
 - SERVO Cable has short
4. Solution: Replace SERVO with following manual
 - Manual: https://traxxas.com/news/how-to-upgrade-slash-servo
5. Configuration:
 - VESC: VESC MK6 HP (purchased in 2023)
 - SERVO: AX2075(traxxas slash stock servo)
 - Motor: Velineon(traxxas slash stock motor)
 - Controler: Nvidia Xavier NX with f1tenth package in ROS2
 - Battery: 3S 5250 DXF Li-po battery
Hope it'll help you.
YoungDawgsCrew
