Motor detection failed/ 0 faults
jnweb29
jnweb29's picture
Alright guys so I have a cheap vesc that was able to update to ackmaniac's 2.54 which is nice. I am not able to get my motor detection to work and the motor doesn't get a signal to it at all. No sound coming from motor, no movement, no nothing at all.. The voltage parameters and everything checks out correctly, but still testing hall sensors and motor detection are failing with no faults.. I tested the motor on a esc does that mean the motor is ok and should work with detection? Or should I check the coils out and take the barrel off? The wires and solder joints have no issues and I am not getting any red lights just blue and greens.
