disappointed with vesc mk6
KCDEF
I have a robotics project, using 750Kv R/C truck motor that is more than capable of brief bursts to 200amps. The motor has plenty of power for the project but has to overcome very brief starting friction and spikes to 160amps. The Vesc wizard gives the motor a paltry 120amps max, which is a bummer because i purchased the Vesc mk6 for its percieved flexibility. Is there anyway around this? if not does anyone want to buy my vesc?
Last seen: 1 week 4 days ago
What are you running that needs such high starting current? You can use HFI to give you much better startup torque and reduce the current required.
