Vesc-tool TCP Connection
nlabs
Hi, Ben.
Previously, I used 'udp-uart-bridge' to communicate with vesc frequently. In the new vesc, There is TCP connection instead of UDP.
Could you explane how to use this TCP connection method?
Thanks,
Dongil Choi
milesf
On your remote machine (e.g. a raspberry pi), use a USB cable to attach the VESC. Then run this socat command on that remote machine to expose the USB device as a TCP socket.
socat tcp-listen:65102,reuseaddr,fork file:/dev/serial/by-id/usb-STMicroelectronics_ChibiOS_RT_Virtual_COM_Port_304-if00,raw
Then on your local machine (e.g. your desktop PC), open VescTool, navigate to Connection>TCP, then enter the remote devices's IP address and click connect.
Note, if socat is unavailable on your remote machine, install it with something like:
sudo apt install socat
