Need advice : repair , vesc 4.12, vesc 6.4 or wait ?
frameto
I've just login to this forum after a quiet long quest of the best solution to my hardware issue (vesc 4.12 from Torqueboards for those who know with firmware/bldc tool 2.18 provided also by this vendor).
I hope my post is in the good discussion folder of this forum and apologize if not (maybe you can suggest the proper site/forum).
Basically the issue is a drv8302 error returned by the "faults" command, and the only mistake identified yet (from discussions with the vendor),  is a wrong value of the "max current ramp step" bldc configuration parameter that was 100 time bigger than the value recommended by the vendor : a bug in a previous version of the bldc / firmware that multiplied by 10 this value each time you write the configuration in the firmware was reported several time in the past on the "builders" forum...
I have made a google doc with all the elements (pictures of the setup, refs of the parts and connections, bldc screenshots, "faults" log...).
But, assuming the "faults" command "tells the truth", my point is to decide what's next now to reach the goal of my "riding program", which is basically 10 km flat riding daily at 35 km/h average speed with a 50 km/h top speed for a total weight of 90 kg (so board included).
So below are the options I see :
  - option A : replace the drv via a contributor offering such a service on the market (internet forums...).
  - option B : buy a new vesc 4.12 compatible with this riding program, as there are on the market.
  - option C : buy a vesc 6 on the market as it is today the best alternative for such a program.
  - option D : wait a little bit, as the vesc 6 (i.e. firmware 6 and/or hardware 6 on the market) will soon be compatible with such a program.
So thanks for any feedbacks on these options and/or suggest other ones, and Have a Nice Day,
Franck
Last seen: 9 hours 17 min ago
If your goal is to gear for a top speed of 50 km/h with a single motor the vesc4 will most likely overheat. The vesc6 should handle it fine if the motor is large enough. I'm not sure what you mean with compatible with such a riding program though and why you would have to wait for vesc6 compatibility.
frameto
Thanks Benjamin for your feedback,
I have two motors like this one, so if they are large enough it's great !
"compatible with such a riding program" : I agree it is not a very precise term...let's say that as the vesc 6 is in it's first releases ( .4 whereas .12 for vesc 4), I was wondering if priority on the vesc 6 development in the short term is more on features requested by most e-riders like braking, foc, battery power saving...and less on higher speed range support ( >= 50 km/h) which most people don't want.
Anyway, your advice matches with other feedbacks and my personal feeling, so I will go for a vesc 6 setup.
Thanks again,
Franck
