Switch between different modes via remote
Cledus
Hi everyone!
I'm new here and pretty new to electric skateboards. I have a DIY-skateboard and I use the nano remote (the one that is called Torqueboards 2,4ghz nano on DIY).The remote has a lot of buttons and I was wondering if it would be possible to map them to different modes? Like on the boards you buy usually have a remote where you can switch between beginner intermediate and advance for example. Would that be possible?
Thanks and take care!
This will be solved through an App in future. The PPM remotes would only be limiting their output signal, which is no sufficient solution.
Frank
MatwoSvK
On nano Remote you have switch on back side same as turn on of in low position you have High and up Low . But it not doing much deference.
https://ibb.co/cZyFiG
