VESC 6 plus working but no servo response
saspragkathos
I am using a VESC 6 plus on a Traxxas RC Car. The software of the car is set up on a NVIDIA Jetson TX2. It was working very well till the Jetson died. The replacement of the Jetson just arrived. I set up all the software for the car but this time the motor is working but the servo isn't responding.
I have tried many different firmware versions (both VESC_default.bin & VESC_servooout.bin) but i have a problem and i cannot understand what's happening.
I have sent PWM signal to the servo via an Arduino Uno and it responds perfectly also. So my servo isn't dead neither its cables. However, i cannot find a solution. Is there anyone that has the same problem or has a solution for me? Do i have to configure somehow the PPM signal of the VESC in order for my servo to respond? I thought that every firmware especially the latest versions support all the communication protocols of the VESC (USB, PPM, CAN etc.) Do i have to tweak something to correct it?
Shreeram2311
Hi saspragkathos,
Did you get the solution. I have the same problem:
I’m running a VESC 60 MK6 on firmware v6.xx with VESC‑Tool v2.05, connected over UART. In the App Settings → General tab, Enable Servo Output is set to True, and I can manually move the steering servo by sliding the control in the VESC‑Tool “Controls” view.
However, when I publish a Float64 message from ROS to /commands/servo/position,
(for example: rostopic pub /commands/servo/position std_msgs/Float64 "{data: 0.5}")
the servo does not move, even though I can see /sensors/servo_position_command echo back the same value.
My motor commands over UART (/commands/motor/speed) continue to work perfectly from ROS, so the serial link and ROS driver appear to be functioning normally.
In conclusion I cannot control the servo to steer the wheels using ROS but the motor commands work normally and I can steer the wheel through VESC Tool. Is it necessary to flash a custom servoout.bin (or similar) image to enable a dedicated UART‑servo app?
If so, where can I obtain the correct firmware build that includes standalone Servo Output support under UART?
RaghulShreeramSivakumaran
