Can VESC be in parallel connection with BMS while being charged?
dfelz
Will the VESC be damaged if it is connected in parallel with the BMS to the battery pack while the BMS charges the battery pack? Would have the VESC powered off, but will the current being sent to the battery pack during charging damage the VESC? If yes i will put a three way switch in, but with the amps we are working with it will have to be a big and expensive switch, so seeing if its avoidable. If i am not explaining the scenario clear enough please let me know so i can elaborate. Many thanks!
-David
It's probably best if you draw out how you will be connecting things.
I think you ought to be okay though.
