how to run two bldc motor in different direction over bluetooth uart data
Raja Sharma
i am using two vesc4.12 connected over CAN and with master i connected bluetooth. i want to rotate both motor in different direction.
when i send 255  at  x and y value. both go forward , and on 0(zero) both go backward but when i send 255 on x and 0 on y in that case also rotate in same direction.
can anyone plese tell to rotate both motor in different direction what data should i send and what setting should i do
complete data format which i am sending over bluetooth.{2,11,35,255,255,0,0,0,0,0,0,0,0,51,185,3}
You can invert the motor direction of one motor if you always want one motor to spin in the other direction. You can invert during the setup wizard, or later on in the Motor Config.
