PPM Arduino throttle AND UART Bluetooth Monitor AND brake lever for braking
vescsci
Hello. I've searched the internet and the forums and cannot get a good idea if this can be done:
I would like to have my scooter use it's hall throttle, and it's brake lever for ebrakes and use the Bluetooth for monitoring.
My setup:
I have a VESC that attaches to a nano Arduino through the servo connector (which is attached to my scooter hall throttle). I use an Arduino, because I have a button that holds the PPM signal for cruise.
I would like to connect my brake lever (which has a switch built in) to the vesc for ebraking. I a Leo want to still be able to use the Bluetooth module and android app for monitoring things.
Can anyone help me with this?
I can do ADC 1 and 2 with UART but I loose the ability to use cruise, right?
I would really like to have my cruise, my brake lever ebrake, and the Bluetooth monitoring.
Thank you, in advance for all the wisdom and help.
Thank you to the forum and to all the developers and users.
