Print statements - Firmware
vitormhenrique
Hello everyone,
let's start with I'm a noob developing rtos systems and st micro controllers, I play around with arduinos, teensys, esp, but nothing close to VESC firmware.
I downloaded the source code, and made some changes, basically updating the ws2811 library. I complied it and flashed on the vesc (i'm using a 4.12 hardware to test) but it did not work.
Is there a way to print statements to terminal, to understand what is going on?
I'm using an ST Link v2 to upload and flash the firmware. But I also get a segger mini.
Documentation says to use commands_printf, and there are a lot of printft statements on the code, but going to the terminal I dont see anything beeing printed.
TLDR: noob wants to print on serial and debug code
MTomoum
Hey vitormhenrique​,
I would do a quick sanity check and confirm you have set the correct baud rate( which is 115200 I believe), bit rate, etc on your computer. Although, I suspect the root of the problem is that the io stream is not being directed correctly to the virtual com port on the st-link debugger. I had a similar problem with my previous project which I some guidance from this link https://www.carminenoviello.com/2015/03/02/how-to-use-stm32-nucleo-serial-port/
I am currently working on digging deep with this firmware specifically uart communication as i am trying to build a custom handheld controller so i will let you know if i have any ideas or suggestions for you. Good Luck!
Muhab Tomoum
Siverian
Siverian's picture
Hello everyone. I'm also interested in debug feature. As I understood it's not possible to debug with a normal debugger with 0 optimization ar with ChibiOS debug feature. So, if someone may share debug experience - it would be interesting.
In this thread https://vesc-project.com/node/1027 a link about debugging an STM32F4 on Benjamins website is mentioned: http://vedder.se/2012/12/debugging-the-stm32f4-using-openocd-gdb-and-eclipse/ Haven't looked at it yet, but maybe that helps a bit.
Siverian
Siverian's picture
Debugging with breakpoints is not straightforward in this case because for this project optimization is set to O2. And if you try to set a breakpoint the further code does not execute straightforward. It jumps somewhere in the program and for me, it's difficult to understand what is going on. But if I disable optimization, the system hangs.
Therefore i'm also interested in "serial debugging" when you send some information to serial port.
