Paragliding rewinder control loop
eptv
I wrote my first control loop for VESC. It was a pleasure, thanks Benjamin for excellent code.
There is a case in paragliding winching with 2 winches. First winch located near takeoff and second far away about 1.3km. The ropes from first and second winches connected together and to the pilot.
When pilot release rope in the sky, first winch should rewind rope back to takeoff.
First winch should hold about 1-2kg of force when second winch pulls pilot to the sky. And apply 15-20kg after pilot release ropes.
Here is my demo:
https://www.youtube.com/watch?v=D2Q30QTi3Ew
And control loop code:
    Copyright 2019 Kirill Kostiuchenko  kisel2626@gmail.com
    This file is part of the VESC firmware.
    The VESC firmware is free software: you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    The VESC firmware is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with this program.  If not, see <http://www.gnu.org/licenses/>.
#include "app.h"
#include "ch.h"
#include "hal.h"
// Some useful includes
#include "mc_interface.h"
#include "utils.h"
#include "encoder.h"
#include "terminal.h"
#include "comm_can.h"
#include "hw.h"
#include "commands.h"
#include "timeout.h"
#include <math.h>
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
// Threads
static THD_FUNCTION(my_thread, arg);
static THD_WORKING_AREA(my_thread_wa, 2048);
// Private functions
static void brake(int abs_tac);
static void unwinding(int cur_tac);
static void rewinding(int cur_tac);
// Private variables
static volatile bool stop_now = true;
static volatile bool is_running = false;
static int prev_abs_tac = 0;
typedef enum
    UNINITIALIZED,
    BRAKING,
    UNWINDING,
    REWINDING
} rewinder_state;
static rewinder_state state;
typedef struct
    int brake_length;             // tachometer range for braking
    int overwinding;              // when going back will rewind a bit more then brake_length -> brake_length - overwinding
    int rewinding_trigger_lenght; // start strong rewinding after going back this length
    int unwinding_trigger_length; // go to unwinding state from rewinding, if this length unwinded
    float brake_current;
    float unwinding_current;
    float rewinding_current;
} rewinder_config;
static rewinder_config config;
static char *state_str(void)
    switch (state)
    case UNINITIALIZED:
        return "unitialized";
    case BRAKING:
        return "braking";
    case UNWINDING:
        return "unwinding";
    case REWINDING:
        return "rewinding";
    default:
        return "unknown";
    commands_printf("rewinder state change: %s -> braking. Abs Tachometer: %d -> %d. Current: %.3fA",
                    state_str(), prev_abs_tac, abs_tac, (double)config.brake_current);
    state = BRAKING;
    prev_abs_tac = abs_tac;
    mc_interface_set_brake_current(config.brake_current);
    timeout_reset();
    // Detect direction depending on tachometer value
    float current = cur_tac < 0 ? config.unwinding_current : -config.unwinding_current;
    commands_printf("rewinder state change: %s -> unwinding. %.3fA current.", state_str(), (double)current);
    state = UNWINDING;
    mc_interface_set_current(current);
    timeout_reset();
    float current = cur_tac < 0 ? config.rewinding_current : -config.rewinding_current;
    commands_printf("rewinder state change: %s -> rewinding. Tachometer: %d. Current: %.3fA",
                    state_str(), cur_tac, (double)current);
    state = REWINDING;
    timeout_reset();
// Called when the custom application is started. Start our
// threads here and set up callbacks.
void app_custom_start(void)
    // Some example lenghts
    config.brake_length = 14;
    config.overwinding = 3;
    config.rewinding_trigger_lenght = 7;
    config.unwinding_trigger_length = 3;
    // Currents
    config.brake_current = 40;
    config.unwinding_current = 7;
    config.rewinding_current = 16;
    state = UNINITIALIZED;
    stop_now = false;
    chThdCreateStatic(my_thread_wa, sizeof(my_thread_wa),
                      NORMALPRIO, my_thread, NULL);
    commands_printf("app_rewinder started");
// Called when the custom application is stopped. Stop our threads
// and release callbacks.
void app_custom_stop(void)
    stop_now = true;
    while (is_running)
        chThdSleepMilliseconds(1);
    commands_printf("app_rewinder stopped");
void app_custom_configure(app_configuration *conf)
    (void)conf;
    (void)arg;
    chRegSetThreadName("App Rewinder");
    is_running = true;
    for (int i = 0;; i++)
        // Check if it is time to stop.
        if (stop_now)
            is_running = false;
            return;
        int cur_tac = mc_interface_get_tachometer_value(false);
        int abs_tac = abs(cur_tac);
        switch (state)
        case UNINITIALIZED:
            if (abs_tac < config.brake_length)
                brake(abs_tac);
            else
                unwinding(cur_tac);
            break;
        case BRAKING:
            // We are in the breaking range?
            if (abs_tac <= config.brake_length)
                // Timeout thread will remove breaking every second by default.
                // Apply breaking if position changed
                if (abs_tac != prev_abs_tac)
                    brake(abs_tac);
            else
                unwinding(cur_tac);
            break;
        case UNWINDING:
            // No timeouts for unwinding state
            if (!(i % 5000))
                timeout_reset();
            // We are in the braking range with overwinding?
            if (abs_tac < config.brake_length - config.overwinding)
                brake(abs_tac);
                break;
            // Use prev_abs_tac as max tachometer
            if (abs_tac > prev_abs_tac)
            // Going back?
            if (abs_tac < prev_abs_tac - config.rewinding_trigger_lenght)
                rewinding(cur_tac);
            break;
        case REWINDING:
            // No timeouts for rewinding state
            if (!(i % 5000))
                timeout_reset();
                brake(abs_tac);
                break;
            // Now use prev_abs_tac as min value
            if (abs_tac < prev_abs_tac)
            // Unwinding again?
            if (abs_tac > prev_abs_tac + config.unwinding_trigger_length)
                unwinding(cur_tac);
            break;
        default:
            commands_printf("Rewinder: unknown control loop state. Exiting!");
            stop_now = true;
        chThdSleepMicroseconds(1);
rookieatbest
Are you able to do tandem with the qs205?
So the reason for the two winches is to pull the line back to take off only? Otherwise only one winch would be needed for a standard pay in system.  During the step tow does the 2nd winch pull as well or is only for the line retrieval?
