PPM Mapping's VESC Tool not working
cornballs
Using Dual FSESC 4.20 Plus and VX1 remote and running FOC with 2 BLDC motors. I go to setup input > Master VESC > PPM RC receiver > PPM mapping. I also turned on RT app data. When I push and pull the throttle, no data is displayed on the "VESC Tool" and "From VESC" bars on the Pulselength section. Remote, receiver, and motors seem to work fine when I hit the throttle outside of the setup. I keep going to "General" to change "APP to use" to PPM instead of PPM and UART, but it doesn't save that option, if that's a relevant problem. Could be the firmware too. I don't know if I bricked the VESC, but I have to keep manually rebooting to setup the input when it tells me the firmware is out of date, even though both VESCs are up to date on v3.61.
clistpdx
Last seen: 6 years 2 weeks ago
Did you ever solve this issue? I've got the same issue, also with my Flipsky dual fsesc 4.20
