Incorrect parameter detection
macieksz@pro.onet.pl
I’ve been trying to configure Flipsky DUAL ESC FSESC6.6 (https://flipsky.net/collections/electronic-products/products/dual-fsesc6-6-based-upon-vesc6-with-aluminum-heatsink) with BLDC motor Maxon EC90 (402687) via VESC Tool. The detected parameters doesn’t match to the datasheet, and the motor doesn’t work properly. Inserting parameters manually according to Maxon’s datasheet didn’t solve the problem either. Choosing different motor sizes at setup didn't change anything.
Motor datasheet: https://www.maxongroup.com/medias/sys_master/8825435389982.pdf
Detected parameteres: https://imgur.com/a/5M5FYfZ
Firmware: 3.58; Hardware: 60
I'l appreciate any form of help.
