VESC with no working brake button
tavsanist
Hello Vesc community,
I have a problem with my maytech 100A vesc. I turned on ADC+UART APP and connected my brake on-off switch to VESC PPM input Ground-Signal wire.
ADC mode is ''current no reverse brake button''
It was working well before then suddenly stopped working. I checked my PPM input port , ground to signal wire , voltage is around 2.3V, checked my brake button, works fine.
I just couldnt figure out what's srong with my setup.
I am using VESC for my ebike. Anyone else experienced this before ? or what are the possible common reasons of such problem ?
