ADC Throttle Voltage Issue
Reichen Schaller
I have had an issue with an ADC throttle and after searching through the forum I found some older threads that had people asking very similar questions but never getting them answered. (As far as I could see that is) The issue is that I am using an ADC foot throttle whose range of inputs seems to exceed that of the ~3.3v maximum for adc1. On the throttle itself it says 0.8-4.2v. Additionally, when I measure the range the VESC sets the 100% at about 80% or the throttle's range. Therefore, when I am driving and push the throttle to full (and therefore past where 100% was) the motor cuts off. I can't seem to raise the maximum voltage to account for the throttle's range. Also, I have used this throttle on a previous ESC build and didn't experience any issues. The first 20% of the throttle seems to have no power and the motor instead just makes a humming noise that reminds me of sensorless motors. (This last part is just me, also I am using a 100/250 vesc)
Any insight or help would be welcome!
You should connect the throttle to3.3V. The pin on the STM processor is not 5V  tolerant! Then you calibrate the throttle, so that full voltage is 100% and minimum voltage is 0%.
There should be a 10K resistor in between ADC1 and GND, close to the port of the VESC controller. If the cable gets damaged, the resistor will pul the signal low ( 0% input).
Reichen Schaller
Got it, I have a 10k resister from making the pre-charge circuitry. (Does it matter that the resistor is 10w?) Right now I have the black to ground, the red wire connected to vcc, and the sensor wire to adc1. How do I calibrate the throttle voltage? I don't see any place to change it in the the wizard.
Reichen Schaller
Reichen Schaller
When you say connect to 3.3v do you mean the little switch hidden inside the 100/250 should be pushed to the 3.3v side?
Reichen Schaller
Reichen Schaller
Update, so the vesc thinks 100% is 3v while the real 100% is 3.35v. I can't figure out how to make the vesc change 100% to 3.35v.
Reichen Schaller
Gatze
You should set the ADC1 End Voltage to 3.3 volts on in the ADC configuration and then mapping tab.
