position hold below specific duty cycle
lacondro
Hi, I'm trying to modify firmware to hold position of motor when duty cycle is below 10%.(FOC with AS5047)
I am a mechanical engineer, so I'm not sure where to begin.
First, I cloned original bldc folder.
From mcpwm_foc.c
Original code
void mcpwm_foc_set_duty(float dutyCycle) {
  get_motor_now()->m_control_mode = CONTROL_MODE_DUTY;
  get_motor_now()->m_duty_cycle_set = dutyCycle;
  if (get_motor_now()->m_state != MC_STATE_RUNNING) {
  get_motor_now()->m_motor_released = false;
  get_motor_now()->m_state = MC_STATE_RUNNING;
changed to
    if(dutyCycle >0.1){
    else{
        get_motor_now()->m_control_mode = CONTROL_MODE_POS;
        get_motor_now()->m_pos_pid_set = 0;
Build and Upload new .HEX file via VESC Tool but it motor runs below 10% duty cycle.
Any suggestions where to fix?
Thanks.
lacondro
I did some modifications and it works!
But too large bin file occurs on v6, so moved to v5.3.
cjmssmd
Last seen: 1 month 2 days ago
Can you post your modifications?  We are looking for exactly this.  We're running in duty cycle mode.  But when commanded duty cycle=0% (or less than 1%..)  we want the motor to hold its position.
Matevz
Me too!
Can anyone post the solution?
