Analogue throttle
craig w
Analogue throttle
Hi
trying to set up a vesc with analog throttle for electric bike. Having a problem with the full throttle only able to go to 3.4 volt were the actual throttle peaks at 5 volt !
is there a way to change the adc1 to full throttle @ 5volt ?
You need to hook it up to VCC (3.3V) and then calibrate it in the Input Wizard, so that 3.xV is full throttle.
craig w
Thanks !
