One trasmitter two receivers
vikiki
Is it possible to tie a single transmitter (e.g. vx1 or nano from flipsky) with two receivers connected to two different vesc? (ppm mode only)
I was trying to use the same ID for VESC using APP but the transmitter only binds with the receivers one at a time.
Thank you in advance
Vincenzo
That depends on the remote and receiver. Some remotes can bind to two receivers. The VESC IDs should always be different and they have nothing to do with your problem. The reciever gets no feedback form the ESC.
vikiki
And how I can figure it out?
May you give me an example of the remote?
Thank you again.
Ask the manufacturer.
Johnvoss
Johnvoss's picture
The Trampa Wand will easily pair with two VESC and control them at the same time.
As Frank said, the Wand is only talking, not listening.
John
