FAULT_CODE_UNDER_VOLTAGE
10 posts / 0 new
alexantosh
Hello, connected my brushless 3500 velineon motor of the traxxas ultimate, to VESC tool 3.0. During motor detection, the wheels attempt to spin but can not turn, they only budge a bit.
battery: 3S, 5200 mAH 25C. The motor configuration am using can be found here. Thanks.
Below are the faults from the terminal, for the first and last entries. What could be the problem here.
The following faults were registered since start:
Fault            : FAULT_CODE_UNDER_VOLTAGE
Motor            : 1
Current          : -18.5
Current filtered : -14.8
Voltage          : 7.94
Duty             : -0.482
RPM              : -53.3
Tacho            : -21
Cycles running   : 1549
TIM duty         : -8100
TIM val samp     : 4200
TIM current samp : 4200
TIM top          : 16800
Comm step        : 0
Temperature      : 24.58
Motor            : 1
Current          : -15.9
Current filtered : -14.6
Voltage          : 8.00
Duty             : -0.544
RPM              : -49.5
Tacho            : -27
Cycles running   : 3459
TIM duty         : -4571
TIM val samp     : 4200
TIM top          : 8400
Comm step        : 0
Temperature      : 24.78
Motor            : 1
Current          : -2.2
Current filtered : -3.9
Voltage          : 7.97
Duty             : -0.548
RPM              : -1.0
Tacho            : -15
Cycles running   : 10983
TIM duty         : -4604
TIM val samp     : 4200
TIM top          : 8400
Comm step        : 0
Temperature      : 25.45
Motor            : 1
Current          : -2.2
Voltage          : 7.97
Duty             : -0.548
RPM              : -1.0
Tacho            : -15
TIM duty         : -4604
TIM val samp     : 4200
TIM top          : 8400
Comm step        : 0
Temperature      : 25.45
for an 3s battery, vbat_min should not be less than 9V,
charge bat. to full and try again, but at least 4s min recomended, in fact.
alexantosh
hello skyline, I did what you suggested but even if the voltage improves, the issue persists. Why is my current so low? Below is the current print out from the  terminal:
Motor : 1
Current : -17.3
Current filtered : -13.1
Voltage : 8.99
Duty : -0.277
RPM : 38.1
Tacho : -21
Cycles running : 2211
TIM duty : -2327
TIM val samp : 4200
TIM top : 8400
Comm step : 0
Temperature : 25.17
in motor settings, general, adjust bat voltage cutoff settings
advanced , min. input voltage
maybe, it could also be tested with an 12v accu.
type of vesc?
alexantosh
Hello skyline, I am using a VESC6 based FSESC6.6. apparently it is using the 60FW, the one without a Mark. alright, I am going to try to set the minimum input battery cutoff voltage to 9v. I did not understand the 12v accu.
On a different note, I wish to recompile the firmware with the servo set as output, is the board i selected below the right one for the with FW:5.2, HW:60? the one without Mark version?
Thanks Skyline1970.
12v ups or car battery
servo output can be provided
alexantosh
thanks alooot. worked. now my motor is spinning happily xd. how can i obtain the servoout?
How do i go about that?
in app. settings, "Enable servo output on PPM-port when PPM-app is disabled." make true
alexantosh
Hello, I do not see any such option in any settings. Even when i choose ppm as the app to use from the general tab. Even under the ppm settings and configurations there is no such option as: "Enable servo output on PPM-port when PPM-app is disabled." . Am using FW: 5.2, HW:60, VESC tool 3.0.
heravinluca
Last seen: 4 years 2 weeks ago
Thank you for your contribution; I hope you will contribute more in the future
1v1 battle
