VESC Tool 3.0 can't run input wizzard
thib
Hi, I have few issues using VESC Tool 3.0 with a MakerX 75200.
I updated the Vesc firmware to the latest version (75_300_ R3  v5.1) using VESC Tool yet I still have a pop up message in VESC Tool notifying the firmware is an old version.
Then I can run the FOC wizard however when I run the input wizard it says it can't run as the VESC is running on an old firmware...
Any help will be greatly appreciated.
Cheers
Tibo
thib
Any idea? I have read others having the same issue
thib
any help would be great. Thanks
thib
Someone can pass the contact of a person able to assist with this issue, it is a bit frustrating. Thanks
Use the latest VESC-Tool, upload the bootloader and then update the firmware. Check if FW updated after upload! Without the bootloader the FW can not update and will fall back to the old version.
The bootloader tab is in the FW section.
