PAS 3-wire sensor : possible to check a digital input under VESC-toool?
marc426
Hi all,
I've tried to implement a 3-wire PAS sensor using a slightly modified code from RobertXuChun : https://github.com/vedderb/bldc/pull/243#issuecomment-809470359
The code is supposedly reading from the TX pin (HW_PAS2_PORT points to HW_UART_TX_PORT under hw.h)
The code compiles correctly but it won't listen to the port. I've even tried with a function generator sending a 1 to 100Hz square signal directly on the TX pin but nothing comes out...
Hence my question : is there any way to check a particular input live / logged under VESC-tool? That'd be most helpful to troubleshoot that.
Best regards,
Marc
marc426
Hi All,
Bumping it up in case someone has an idea on how to debug a digital input! :-)
in sw if uart is active, pas does not work, uart should be disabled, maybe, servo pin, would be better for pas.
marc426
Hi Skyline, this is of course using the PAS setting under app (so disabling UART I assume).
Do I need to disable it in code?
PAS setting under app ,so disabling UART in fw should not be necessary unless there is no an issue in sw.
marc426
OK,
In that case I guess there is another issue in SW or else. I'm going to try to use some other GPIO pin and see what happens.
velolac
Last seen: 5 months 21 hours ago
Hi marc,
Have you succeeded in using a 3 wire PAS sensor? After quite a bit of search I only found quadrature (4 wired) PAS sensors at grin technologies. However I found out that dual channel hall sensor chips can be bought cheap (~ $3) , so I will make custom sensor. Still, I found no documentation about which ports shall be used for the 4 wired PAS. Do you happen to know it?
I am not sure how hard would it be for me to dig into a bit of coding as it shall be quite easy what I would like to achieve, too bad I have only basic knowledge in programming. I would basically use the PAS sensor signal to ignore the ADC input if there is no pedaling. It varies a lot how much assist I actually need, so keeping the throttle is beneficial for me.
