Motor RPM not stable FW 5.03
TZTZ
Hey,
I am having the same issue as in this post: https://vesc-project.com/node/2647 But when i try to do BLDC detection it keep saying that it fails and that i need to change parameters, i have tried every possible argument within 5A range and the allowed range(without getting invalid arguments)
I am using a micromotor cm62 http://www.micromotor-bg.com/Products/Product/40 with only ~100g inrunner which should run between 7000 and 40000 RPM 2 poles
These are my values:
It runs fine within the openloop time 5 seconds(but in the FOC detection the motor does sound better compared to the openloop), but when it gets out of it the motor kind of restarts.
I get that my resistance is high but it changes by a lot with usage/heat when it is colder it is below 1000 and now it is shower temperature and it is the screenshot.
Best Regards,
Piet
TZTZ
Hey, doing the same thing but then using the new beta firmware 5.03 it does work fine! only my rpm aint stable/duty cycle.
I am driving it with duty cycle but when it goes above 10000 RPM you can clearly see the spikes in the RPM plot
