VESC 100/250
XBO
VESC 100/250
I just bought the VESC 100/250 and I got the VESC hardware in a box and thats all.
I had a look into other videos and people how bought the VESC 75/300 got a lot of things delivered. Such as cables, connectors, etc...
Why is the delivery of bothe VESC hardware so different?
They probably purchased all the stuff they needed. We do not know what a customer needs, so we rather deliver it without tons of cables and connectors. This way we can keep the price tag a bit lower and you can decide what exactly you really need for your project.
https://trampaboards.com/cables-connectors--consumables-c-973.html
Manual:https://trampaboards.com/resources/manuals/222.pdf
XBO
Hi Frank,
Well I understood the point, but if you think properly the VESC 100/250 i.e. has a 3 inputs to be had connected to the output of the batteries, correct ?
Now I need to weld 9 cables (inputs) to a 3 outputs from the battery.
This is DIY and should for the extreme high cost of the VESC 100/250 at least be deliver this 3 Cables.
Dont you think ?
Edit:
You dont have even this cable in your store.
You have only this cable with 2 inputs and 1 XT90 output
https://trampaboards.com/4mm-bullet-to-xt90-conversion-plug-with-extensi...
Fpvlee
You will be lucky if you get any type of answer XBO!Its like pulling blood from a stone on this forum
The 100/250 is pretty small for what it delivers, so we feed the power directly into the 3 power stages. We also don't need thick and stiff cable this way. In future we might offer a design with screw terminals.
