Limp mode via CAN
totalgeek9224
Limp mode via CAN
If some sort of parameter were to be able to cause the VESC to enter Limp mode, via a signal over CAN, it would allow for the hardware to protect itself.
An implementation of this could be considered with a BMS. If a CAN enabled BMS could communicate to the VESC, triggering a limp mode, in which acceleration cannot be increased, and braking ability remains, this could prevent a hard cut-off being reached, or possible hardware failure (eg a battery fire due to severely discharged P group).
A2
the weird thing on my setup is that some boards do have limp mode (going <5mph near the end of the battery) and some do not. Any idea why this would be?
A2
A2
for some reason I have some boards I have made that have limp mode (going <5mph at low battery) and some just go full power until battery cutoff. Any idea how this could happen? all the same software and hardware.
