VESC 75/300 vs VESC 100/250
XBO
Can someone tell me the difference between the
VESC 75/300
vs
VESC 100/250
? I bought the VESC 100/250, because the VESC project hasnt the VESC 75/300 for a couple of weeks.
Now Im a bit confuse!
Can someone share the difference between those 2 hardwwares?
Thanx in advance!
Cheers!
The 75/300 can push more amps and is a 3 phase shunt design. It also features higher built in cpacitisatnce.
The 100/250 can push less amps but can run at higher voltages. So power wise it is the same, but you need to apply higher voltages. It has 3 shunts on the battery side.
For low inductance motors the 75/300 is better, since it features 3 phase shunts. If your system voltage is 16S and lower. the 75/300 would also be your choice.
XBO
Awesome!
Thank you for the very fast reply.
I got the point.
flyingbrike
flyingbrike's picture
Hello
Where can i connect a power switch to my MakerX HI200  75200?
Silent Revolution is NOW !
