PWM on output
ml2311
Last seen: 5 years 1 day ago
PWM on output
Dear all,
I would like to add a PWM to control and have a feedback on the motor RPM. Is there a specific cable plan or any tips to do this?
I am using the MTVESC7.12 V2 50V 200A VESC75/300 based Speed Controller.
Thank you!
Flyingtux
Last seen: 1 year 2 weeks ago
I'm interest too to have the rpm info in a pwm output to be able to check the current rpm in a external device,
Thanks if somebody can help
Flyingtux
no news on that features ?
sp3swj
In this project is used  PPM port as  output for serwo control
https://github.com/RacecarJ/vesc-firmware
Jarek sp3swj
Flyingtux
Thanks Jarek,
but currently in the code i'ts cheese or desert. I mean even pwm input(to command vesc) or pwm output (to commande a servo).
I would like to conserve pwm input and add a erpm output on another IO.
Regards,
Flyingtux
does anybody could help to configure simple servo output on AUX instead of servo
I put this in servo_simple.c:servo_simple_init(void)
#ifdef SERVO_SIMPLE_USE_AUX_PIN
    palSetPadMode(AUX_GPIO, AUX_PIN, PAL_MODE_ALTERNATE(HW_ICU_GPIO_AF) |
            PAL_STM32_OSPEED_HIGHEST | PAL_STM32_PUDR_FLOATING);
#else
    palSetPadMode(HW_ICU_GPIO, HW_ICU_PIN, PAL_MODE_ALTERNATE(HW_ICU_GPIO_AF) |
#endif //SERVO_SIMPLE_USE_AUX_PIN
commands_printf("Servo Output Initialized\n");
I put this in hw_75_300.h to disable any call to AUX_ON() or AUX OFF()
#define AUX_GPIO                GPIOC //external led, original was GPIOC
#define AUX_PIN                    12 //external led, original was 12
#define AUX_ON()
#define AUX_OFF()
#else
#define AUX_ON()                palSetPad(AUX_GPIO, AUX_PIN)
#define AUX_OFF()                palClearPad(AUX_GPIO, AUX_PIN)
I can read "Servo Output Initialized" in terminal put no output on AUX_PIN !!!!
