IMU and ADC1/2 not working
Dwal
I purchased a Floatwheel kit and can't get any response out of them.  It has the BalancePro V6.6+ and VESC tool can't read the IMU or the foot pad sensor (ADC1, ADC2).  I have watched a few videos and tried to set it up multiple times.  Is it a bad VESC?  If it is bad can it be replaced with the VESC 6 MKV?  Thanks in advance for the help.
danilolattaro
Are you on the Floatwheel discord?
We can support you there.
There has been at least 2 cases of people with bad BalancePros with dead IMUs, so it is a possibility.
However with dead ADCs is the first time I've seen.
Are you sure you have "RT", "RT APP", and "IMU" buttons clicked, on the right side of vesc tool?
Finally, yes, you may use a VESC 6 MKV instead.
BP is based on VESC 6+.
Dwal
Thanks for the reply.  I purchased the VESC 6 MKV and it works perfect.  Deffinetly better quality than the floatwheel.
