VESCTool - connect to ESP32?
SimonR_SFX
Last seen: 5 months 19 hours ago
VESC FreeVESC Silver
I wonder if anyone has connected the VESC Tool to an ESP32, instead of a dongle?
My reason for this is I have a display connected to the UART pins - but would like to use the VESC Tool at the same time!  Since the ESP32 supports Bluetooth 4, I wonder if it could just act as a relay, extracting the info it needs for the display as it goes?
The display is here (if you're interested) https://github.com/SimonRafferty/VESC_ESP32_Display
danilolattaro
Yes, it is possible to just forward all the UART communication through the ESP32.
There's a gentleman who already worked that out https://github.com/thankthemaker/rESCue
It is also possible to tunnel the UART through CAN, which is how metr.at do on their CAN version module, however that's still not implemented on thankthemaker's code.
