Documentation - Input Setup Wizard for multiple VESCs via CAN-Bus, using a PPM signal radio controller
Enak
The documentation for Input Setup Wizard for multiple VESCs via CAN-Bus, using a PPM signal radio controller is in need of a small update.
Since the latest firmware now scans canbus a few of the steps need updating to show the new process of running the wizard.
Jreamer
How does one set up the slave VESC now?
jpk
spacewalker
Over CAN is easy , becsuse  is detecting 2 ID's  , and you can select which one you want to program
Martin
The manuals will get an update after the next release.
