compiling with new mcconf_default.h and appconf_defaut.h does not seem to work
owhite
Folks,
I did a dump of header files from vesc-tools with customized values
Then, starting with a clean build from github for vesc I made sure that conf_general.h pointed to mcconf_default.h and appconf_default.h
I compiled, flashed on to a vesc board using st-link, connected vesc tool, and I expected that my default values would appear in the tool. Going to "read motor configuration" and "read app configuration" did not change any values.
In one specific case I changed the value of:
#define MCCONF_L_MAX_VOLTAGE			100
and that didnt appear in the configuration -- I got "maximium input voltage" of 57 of the advanced tab.
In another example I set
#define APPCONF_UART_BAUDRATE				19200
And was expecting that to change my baudrate in UART panel
any suggestions for how I can compile and flash to set the default values parameters for the VESC?
thanks.
owhite
Please ignore -- I was able to get it to work although the only change seemed to be from performing the compile/flash multiple times.
