Flipsky 7550 and Ninebot Max G30 48V
shatty
Hi guys.  So I have a Ninebot Max G30.  Installed the 7550 in it.  Im running a 13s6p 48V battery and the Gen 2 Ninebot Max motor. (350/700 watts).  I got the wheel spinning and brake working.  I am confused as to what settings the motor should be set for.  FOC or BLDC.  When set on BLDC sensored, the wheel jerks at the touch of the throttle.  Unsensored make a little whine but sounds fast AF.  FOC sounds tamed down weather in sensored or unsensored.  Just to make sure, the Blue wire goes to A, Brown to B, and Yellow to C.  On the Hall sensor plug from motor, I have red, black, yellow, blue, green.  Obvioulsy red is V+ and black is ground, blue to H1, green to H2, and yellow to H3.  Does it matter the order for ABC wires?  What about H1,H2,H3 wires?
shatty
I did the autodetect, buttoned it up and tested.  Throttle works, brake works, but when the motor is trying to go its stuttering.  Did i break the hall sensors?
