Motor dosent run normaly, it jerky like crazy.
lumosi
Today I tray to configure my e-bike Motor with a Maytech 6.0 200A VESC HW 60 FW 5.2.
The Motor jerks like crazy, could somebody help?
How can I upload a sample?
dsuresh
are you having this issue at lower speeds? I am having the same issue. Also are you using ADC or PPM
Dave
lumosi
Hi Dave, verwende ADC. Das Ruckeln steigert sich mit der Drehzahl und dann stopt der Motor. Die Drehzahl ist sehr niedrig.
Gruß lumosi
dsuresh
I had similar issue using PWM. but when i used adc and connected a potentiometer, used duty cycle in the setup menu. i was able to get a smooth motor speed. check that out
Dave
