Need some help on motor config and app config for Flypsky 65161 motor with FSESC75200 75V
freedomBoogie
Hi Everyone,
We are building an electric boogie board(Tow boogie) to tow folks on their foil board. Here is a youtube video that shows how it works.https://www.youtube.com/watch?v=AXAEtRpQjOA.
Our Tow Boogie Build has run into issues with the speed of the boogie. The motor doesn’t seem to be generating enough speed. For starters we followed the boogie on a surfboard and got up to 7mph speed.
So we are testing the setup in the swimming pool with the board out of the water and the motor and prop in the water. We are getting only
max ERPM:5000
Max motor current : 48A
Battery Current: 25A
When we push the motor past 48A, the motor stutters and lose thrust and the motor current falls to 30A but will still keep running. If we back off the throttle, then the motor will start picking up the speed again but will hit the stutter at 48A.
The Battery pack is capable of delivering upto 225A. There are 3 battery packs connected in parallel . Each Battery packs is 14S 5P of 21700 which gives 50V , 75A.
We suspect the FSESC settings. We’ve been tweaking the FSESC config through VESC Tool and are not able to figure out why the FSESC is not driving the Current above 48Amps. Hoping to get help from the experts here in this forum. If anyone has a working motor config and appconfig for Flipsky Fsesc75200-75v and 65161-120KV-motor setup that’ll be super helpful.
Specs for FSESC and 65161 motor:https://flipsky.net/collections/groups/products/group-f7-water-sports-kit-includes-high-current-fsesc75200-75v-and-65161-motor
Here is the wiring diagram
2021_02_27 11_14 PM Office Lens
2021_02_27 11_14 PM Office Lens2383×2818 670 KB
My Appconfig: https://drive.google.com/file/d/1RpfGdOI42ga4fny7EF2PO7UXChiADpEr/view?usp=sharing
My MotorConfig:https://drive.google.com/file/d/1qAZzRmyk8V83cow99QxzeYZmvcPesmbL/view?usp=sharing
freedomBoogie
Here’s the log from one of the test run.
Batt_current (red)
Motor_current (green)
Duty_cycle (black)
eRPM/1000 (Blue)
fsesc-logs
fsesc-logs1380×694 108 KB
Raw data:
Time(sec) voltage Batt_Current Motor_current Duty_cycle RPM/1000
4.63 50.00 0.00 0.29 0.00 -0.00
5.63 50.10 0.00 0.29 0.00 -0.00
6.63 50.20 0.00 0.29 0.00 -0.00
7.63 50.10 0.00 0.29 0.00 -0.00
8.63 50.20 0.00 0.29 0.00 -0.00
9.63 50.20 0.00 0.29 0.00 -0.00
10.63 50.10 0.00 0.29 0.00 -0.00
11.63 50.10 0.00 0.29 0.00 0.00
12.63 50.10 0.00 0.29 0.00 0.00
13.63 50.10 0.00 0.28 0.00 0.00
14.63 50.10 0.00 0.29 0.00 0.00
15.63 50.10 0.00 0.28 0.00 0.00
16.63 50.10 0.00 0.29 0.00 0.00
17.63 50.10 0.00 0.29 0.00 0.00
18.63 50.20 0.00 0.29 0.00 0.00
19.63 50.10 0.00 0.29 0.00 0.00
20.63 50.10 0.00 0.28 0.00 0.00
21.63 50.20 0.00 0.29 0.00 0.00
22.63 50.00 0.00 0.29 0.00 0.00
23.63 50.10 0.00 0.29 0.00 0.00
24.63 50.10 0.00 0.28 0.00 0.00
25.63 50.10 0.00 0.28 0.00 0.00
26.63 50.10 0.00 0.28 0.00 0.00
27.63 50.10 0.00 0.28 0.00 0.00
28.63 50.10 0.00 0.28 0.00 0.00
29.63 50.10 0.00 0.29 0.00 0.00
30.63 50.10 0.00 0.28 0.00 0.00
31.63 50.20 0.00 0.28 0.00 0.00
32.63 50.10 0.00 0.28 0.00 0.00
33.63 50.10 0.00 0.29 0.00 0.00
34.63 50.00 0.00 0.29 0.00 0.00
35.63 50.00 0.00 0.28 -0.00 0.00
36.63 50.10 0.00 0.29 0.00 0.00
37.63 50.10 0.00 0.29 0.00 0.00
38.63 50.10 0.00 0.28 0.00 0.00
39.63 50.10 0.00 0.28 0.00 0.00
40.63 50.00 0.00 0.28 0.00 0.00
41.63 50.10 0.00 0.29 0.00 0.00
42.63 50.20 0.00 0.28 0.00 0.00
43.63 50.10 0.00 0.28 0.00 0.00
44.63 50.00 0.00 0.28 0.00 0.00
45.63 50.10 0.00 0.28 0.00 0.00
46.63 49.50 1.41 3.21 0.55 4.68
47.63 50.00 6.88 13.55 0.00 0.03
48.63 50.10 0.00 0.27 0.00 0.01
49.63 50.10 0.05 1.09 0.09 1.25
50.63 50.10 0.73 7.51 0.11 1.70
51.63 50.10 0.97 8.39 0.12 1.67
52.63 50.00 1.18 9.55 0.13 2.01
53.63 50.10 1.49 10.99 0.13 2.06
54.63 50.00 1.92 12.46 0.16 2.23
55.63 50.00 2.41 14.21 0.20 2.69
56.63 50.00 3.65 18.54 0.20 2.79
57.63 50.20 4.04 19.42 0.26 3.05
58.63 49.80 5.35 22.29 0.24 2.95
59.63 49.80 5.34 22.30 0.23 2.98
60.63 49.70 6.19 23.96 0.27 3.22
61.63 49.80 6.89 25.43 0.25 3.18
62.63 49.70 6.91 25.48 0.21 3.23
63.63 49.70 6.95 25.54 0.23 3.24
64.63 49.60 8.97 29.48 0.35 3.49
65.63 49.50 9.68 30.83 0.24 3.51
66.63 49.70 9.57 30.72 0.34 3.48
67.63 49.30 12.41 34.69 0.36 3.87
68.63 49.60 14.34 37.38 0.42 4.00
69.63 49.40 14.29 37.42 0.29 3.86
70.63 49.20 15.12 38.11 0.44 3.98
71.63 49.70 18.62 41.44 0.45 3.92
72.63 49.30 18.63 41.13 0.44 4.19
73.63 49.20 18.57 41.29 0.46 3.98
74.63 48.90 20.86 43.37 0.42 4.65
75.63 48.70 24.88 47.91 0.54 4.60
76.63 48.20 24.85 48.34 0.43 3.83
77.63 49.00 24.89 48.33 0.54 4.69
78.63 49.10 24.90 48.08 0.64 4.43
79.63 49.00 24.87 48.59 0.47 4.55
80.63 49.30 24.73 48.30 0.47 4.50
81.63 48.90 24.97 48.54 0.55 4.59
82.63 48.70 24.90 48.40 0.56 4.41
83.63 49.70 23.11 45.98 0.14 2.61
84.63 50.00 0.00 0.34 0.00 0.01
85.63 49.90 0.00 0.34 0.00 0.00
86.63 49.90 0.00 0.33 0.00 0.00
87.63 49.90 0.00 0.33 0.00 0.00
88.63 50.00 0.00 0.33 0.00 0.00
89.63 49.90 0.00 0.33 0.00 0.00
90.63 49.90 0.00 0.33 0.00 0.00
91.63 49.90 0.00 0.33 0.00 0.00
92.63 50.00 0.00 0.33 0.00 0.00
93.63 49.90 0.00 0.33 0.00 0.00
94.63 50.00 0.00 0.33 0.00 0.00
95.63 49.90 0.00 0.32 0.00 0.00
96.63 50.00 0.00 0.32 0.00 0.00
97.63 50.00 0.00 0.32 0.00 0.00
98.63 50.00 0.00 0.32 0.00 0.00
99.63 49.90 0.00 0.32 0.00 0.00
100.63 49.90 0.00 0.32 0.00 0.00
101.63 50.00 0.00 0.32 0.00 0.00
102.63 50.00 0.00 0.32 0.00 0.00
103.63 50.10 0.00 0.32 0.00 0.00
104.63 50.00 0.00 0.32 0.00 0.00
105.63 50.20 0.00 0.33 0.00 0.00
106.63 50.00 0.00 0.40 0.00 0.02
107.63 50.00 0.01 0.60 0.01 0.51
108.63 50.00 0.29 2.24 0.00 0.13
109.63 49.70 16.26 35.73 0.21 2.09
110.63 49.20 16.14 36.82 0.47 4.27
111.63 49.30 24.65 47.35 0.27 3.96
112.63 49.20 10.41 22.19 0.63 4.51
113.63 49.00 24.55 47.93 0.42 4.62
114.63 50.00 3.22 7.25 0.00 0.02
115.63 50.00 0.00 0.32 0.01 0.01
116.63 49.10 21.93 44.31 0.57 4.34
117.63 49.60 21.75 44.49 0.20 3.38
118.63 49.80 7.93 19.08 0.14 0.66
119.63 49.60 1.14 4.72 0.30 2.58
120.63 48.90 23.24 46.33 0.46 4.53
121.63 48.90 24.52 47.67 0.43 4.56
122.63 49.90 6.94 14.40 0.00 0.03
123.63 49.90 0.01 0.49 0.00 0.02
124.63 49.90 0.04 0.77 0.00 0.14
125.63 50.00 0.00 0.20 0.00 0.01
126.63 49.90 0.42 3.04 0.01 0.42
127.63 49.80 0.00 0.28 0.00 0.01
128.63 49.30 0.89 3.25 0.40 3.91
129.63 49.10 22.79 45.71 0.56 4.64
130.63 49.10 19.39 40.95 0.53 4.46
131.63 49.10 15.95 34.06 0.64 4.35
132.63 49.90 16.52 33.20 0.02 0.49
133.63 49.00 2.37 6.12 0.49 4.33
134.63 48.90 24.46 47.51 0.44 4.60
135.63 49.00 24.32 47.71 0.50 4.55
136.63 49.10 24.05 47.62 0.51 4.51
137.63 49.00 24.19 47.67 0.41 4.14
138.63 49.30 16.32 35.80 0.45 4.01
139.63 49.00 23.90 47.38 0.53 4.29
140.63 48.90 23.39 46.69 0.42 4.43
141.63 48.90 23.10 46.62 0.53 4.43
142.63 48.80 23.05 45.60 0.42 4.47
143.63 49.00 23.22 46.08 0.45 4.39
144.63 49.80 1.73 4.27 0.00 0.01
145.63 49.80 0.00 0.32 0.00 0.00
146.63 49.80 0.00 0.31 0.00 0.00
147.63 49.90 0.00 0.32 0.00 0.00
148.63 49.80 0.00 0.31 0.00 0.00
149.63 49.90 0.00 0.31 0.00 0.00
150.63 49.80 0.00 0.31 0.00 0.00
151.63 49.80 0.00 0.31 0.00 0.00
152.63 49.90 0.00 0.32 0.00 0.00
153.63 49.90 0.00 0.31 0.00 0.00
154.63 49.90 0.00 0.31 0.00 0.00
155.63 49.90 0.00 0.31 0.00 0.00
156.63 49.90 0.00 0.31 0.00 0.00
157.63 49.90 0.00 0.31 0.00 0.00
158.63 50.00 0.00 0.31 0.00 0.00
159.63 49.90 0.00 0.31 0.00 0.00
160.63 49.90 0.00 0.31 0.00 0.00
161.63 50.00 0.00 0.31 0.00 0.00
162.63 49.90 0.00 0.31 0.00 0.00
163.63 49.90 0.00 0.31 0.00 0.00
164.63 49.90 0.00 0.31 0.00 0.00
165.63 49.90 0.00 0.31 0.00 0.00
166.63 50.00 0.00 0.31 0.00 0.00
167.63 49.90 0.00 0.32 0.00 0.00
168.63 49.90 0.00 0.31 0.00 0.00
169.63 50.00 0.00 0.31 0.00 0.00
170.63 49.90 0.00 0.31 0.00 0.00
171.63 49.90 0.00 0.32 0.00 0.00
172.63 50.00 0.00 0.31 0.00 0.00
173.63 49.90 0.00 0.31 0.00 0.00
174.63 49.80 0.00 0.31 0.00 0.00
175.63 50.00 0.00 0.31 0.00 0.00
176.63 50.00 0.00 0.31 0.00 0.00
177.63 49.90 0.00 0.31 0.00 0.00
178.63 49.90 0.00 0.31 0.00 0.00
179.63 49.90 0.00 0.31 0.00 0.00
180.63 50.00 0.00 0.31 0.00 0.00
181.63 50.00 0.00 0.31 0.00 0.00
182.63 49.90 0.00 0.31 0.00 0.00
183.63 49.90 0.00 0.31 0.00 0.00
184.63 50.00 0.00 0.31 0.00 0.00
185.63 50.00 0.00 0.31 0.00 0.00
186.63 50.00 0.00 0.31 0.00 0.00
187.63 50.00 0.00 0.31 0.00 0.00
188.63 50.00 0.00 0.31 0.00 0.00
189.63 49.90 0.00 0.31 0.00 0.00
190.63 49.90 0.00 0.31 0.00 0.00
191.63 49.90 0.00 0.31 0.00 0.00
192.63 50.00 0.00 0.31 0.00 0.00
193.63 50.00 0.00 0.31 0.00 0.00
194.63 50.00 0.00 0.31 0.00 0.00
195.63 49.90 0.00 0.31 0.00 0.00
196.63 50.00 0.00 0.31 0.00 0.00
197.63 49.90 0.00 0.31 0.00 0.00
198.63 50.00 0.00 0.31 0.00 0.00
199.63 50.00 0.00 0.31 0.00 0.00
200.63 50.00 0.00 0.31 0.00 0.00
201.63 49.90 0.00 0.31 0.00 0.00
202.63 50.00 0.00 0.31 0.00 0.00
203.63 49.90 0.00 0.31 0.00 0.00
204.63 49.90 0.00 0.31 0.00 0.00
205.63 49.90 0.00 0.31 0.00 0.00
206.63 49.90 0.00 0.31 0.00 0.00
207.63 50.00 0.00 0.31 0.00 0.00
208.63 49.90 0.00 0.31 0.00 0.00
209.63 49.90 0.00 0.30 0.00 0.00
210.63 50.00 0.00 0.31 0.00 0.00
211.63 50.00 0.00 0.31 0.00 0.00
212.63 50.00 0.00 0.31 0.00 0.00
213.63 50.00 0.00 0.31 0.00 0.00
214.63 50.00 0.00 0.31 0.00 0.00
215.63 50.00 0.00 0.31 0.00 0.00
216.63 49.90 0.00 0.31 0.00 0.00
217.63 49.90 0.00 0.31 0.00 0.00
218.63 49.90 0.00 0.31 0.00 0.00
219.63 50.00 0.00 0.31 0.00 0.00
220.63 50.00 0.00 0.31 0.00 0.00
221.63 50.00 0.00 0.31 0.00 0.00
222.63 49.90 0.00 0.31 0.00 0.00
223.63 50.00 0.00 0.30 0.00 0.00
224.63 50.00 0.00 0.31 0.00 0.00
225.63 50.00 0.00 0.31 0.00 0.00
226.63 49.90 0.00 0.31 0.00 0.00
227.63 50.00 0.00 0.31 0.00 0.00
228.63 50.00 0.00 0.31 0.00 0.00
229.63 50.00 0.00 0.31 0.00 0.00
230.63 50.00 0.00 0.31 0.00 0.00
231.63 50.00 0.00 0.31 0.00 0.00
232.63 49.80 0.00 0.30 0.00 0.00
233.63 50.00 0.00 0.31 0.00 0.00
234.63 50.10 0.00 0.31 0.00 0.00
235.63 50.00 0.00 0.31 0.00 0.00
236.63 49.90 0.00 0.31 0.00 0.00
237.63 49.90 0.00 0.30 0.00 0.00
238.63 50.00 0.00 0.31 0.00 0.00
239.63 50.00 0.00 0.31 0.00 0.00
240.63 50.00 0.00 0.31 0.00 0.00
241.63 50.00 0.00 0.31 0.00 0.00
242.63 50.00 0.00 0.31 0.00 0.00
JoeSwe
Did you solve your config problem? We are three Tow Boogie builders with a similar setup looking to find better motor parameters.
