make and make upload okay, but no connection
martin2day
i build an VESC 6 hardware for my RC Boat.
Today i solder the MCU board and now i want to connect to pc, but i can't get any connection via USB.
I run Virtual Box vor make and make upload the code. At the end i get the massage "Vertivy OK"
Than i run VESC Tools 3.0 for mac but get no connection. I use a simular routing of the 75/300 so i use the HW from this conntoller.
Please help me
Thank you very much
Martin
CTSchorsch
We found a workaround:
Martin used a 16MHz oscillator instead 8MHz. Right now we use #define HW_USE_INTERNAL_RC as a workaround
Is it possible to change the clock settings in mcuconf.h to use a 16Mhz one ?
it should, whole hal settings, pll etc.. important  cubemx could specify correct settings.
CTSchorsch
okay, i recommended to solder a 8Mhz :) sounds much easier
