HALL-FOC---don't understand the mcpwm_foc_hall_detect() function
ConnerL
ConnerL's picture
       All I know is that the  mcpwm_foc_hall_detect() function is used to calculate  the initial Angle of  the sector corresponding  to the HALL sensor. The results are stored in  hall_table[].
For the details,  there's something in the code of mcpwm_foc_hall_detect() that I don't understand:
 //--------------------------------------------code section-----------------------------------------------------
  // Forwards
    for (int i = 0;i < 3;i++) {
        for (int j = 0;j < 360;j++) {
            motor->m_phase_now_override = (float)j * M_PI / 180.0;
            chThdSleepMilliseconds(5);
            int hall = utils_read_hall(motor != &m_motor_1);
            float s, c;
            sincosf(motor->m_phase_now_override, &s, &c);
            sin_hall[hall] += s;
            cos_hall[hall] += c;
            hall_iterations[hall]++;
    // Reverse
        for (int j = 360;j >= 0;j--) {
            float s, c;
//-----------------------------------------------code section--------------------------------------------------
Q1:  Why use a for loop?
Q2:  Will The HALL state be change on each loop , because of the delay about 5ms?
Q3:  Why do we need to distinguish between Forwards and Reverse?
Q4:  Can you explain this iteration principle? or offer some ideas about math?
Thank you very much.
  1. The nested for loops rotate the motor through 3 electrical revolutions. The current used to rotate the motor is probably set a few lines before the code you pasted.
  2. The expected behaviour is 6 hall states per electrical revolution.
  3. I believe that will help determine the offset in the physical placement of the halls.
  4. Not exactly sure what you are asking here?
ConnerL
ConnerL's picture
Thank you for your reply.
For the 4th ,   I want to ask  you some questions about the loop that rotate the motor through 1 electrical revolution (for (int j = 360;j >= 0;j--))
1. The cycle pace is 1 degree, so the motor actually turns 1 degree ,YES or NO ?
    code: motor->m_phase_now_override = (float)j * M_PI / 180.0;
2.  What is the purpose of iteration with sin and cos ?
Best Regards
Conner
