One remote, two FSESC4.20 (wirelessly)?
fogus
Howdy.
I'm working on a project to create electric roller skis: two skis (no wires between them) and one remote.
In my possession, I have two FSESC4.20 ( https://flipsky.net/collections/electronic-products/products/mini-fsesc4... ), one VX2 Remote ( https://flipsky.net/collections/accessories/products/screen-remote-vx2-f... ) and two 2.4G RC receivers ( https://flipsky.net/collections/accessories/products/flipsky-2-4g-rc-rec... ).
As I'm sure you have figured out, I can only pair the remote with one receiver at a time.
I'm also aware of a (non-viable) solution: put a CAN Bus connector ( https://flipsky.net/collections/accessories/products/dual-esc-can-bus-co... ) between the VESCs.  This is non-viable because the VESCS must not be connected by wires (wires would snag on the ground or have to be run inside my pants).
What are my options?
  1. Could I use a different style of receiver?  My VESCs have (unused) ADC and ADC2 ports--could I use these somehow?
  2. Could I create wireless CAN bridge (without breaking the bank--say <$100)
I have seen video of someone pairing one remote with two ESCs, so I know it's possible in theory.  It's a question of which parts I need and which parts I need to return.
Thanks.
Rashid1992
I don't know how savvy you are with micorcontrollers but i am facing a very similar issue, i am designing a pair of electric roller blades and having a working prototype with everything wired to a dual 4.12 in a bag. Next stages is to get them all in the boot and to overcome the split VESCs working wirelessly im thinking of using three arduinos.
Have a master arduino in a remote with a transmitter and two arduinos as slaves with receivers, set unique identifiers and just transmit an analog value over consistently which i will use in the ADC ports.
Something like the following video but adapt the hardware and software for one way communication to two arduinos: https://www.youtube.com/watch?v=7rcVeFFHcFM
Just my thoughts, i was looking for a ready made solution to my issue and this came up
RASHID MUSTAFA
