no sensor code
steven@clarkeco...
no sensor code
hi all im new to vesc and keep getting the same fault code when doing a foc wizard motor check. The code is ' detection failed . reason: sensor detection failed'
I have had this code on several differant motors and vesc . Any advice?
Andreas1030
i am having the same problem.
TheFallen
Last seen: 7 months 6 hours ago
Have you tried any debugging steps?
The error is saying it can't find the position sensors that you said were attached to the motor.
What kind of sensors are you using?
How are they attached?
Do they work?
Have you tried running the detection sensorless?
