How to RC segway Ninebot pro using BALANCE mode? $$
zmei116
Hi.
Bought two vesc 6mk3. Removed all segway brains and use only two vesc. I am Using it on my Segway Ninebot with "app to use" in "Balance mode".
BUT how to RC my segway with a standard RC system?
I am new in it, so need more explanation step by spet if it is possible :).
I can pay for your help, if you don't have enough time to explain here everything i need to know.
Thanks. Best regards Andrii Shramko.
vitormhenrique
Hello Andrii​,
Gow now the balancing app only works with one motor, so it will not wor with two motors linked. I think changes to allow two motors system linked on a canbus are on the works.
Either way, nunchuck / remote input when you are on balancing mode might is disabled, you would need to write a custom app that has the balancing stuff and joystick control, that is a "fairly" advanced thing if you have no programing skills and know VESC firmware.
zmei116
so, now the balance mode work with two motors. Is it possible to make remote controlled segway using one RC transmitter?
zmei116
Is it possible to create a RC two wheel segway from new dual vesc ?
