VESC6 Motor stuttering/shutoff while accelerating
AM3R0
Hey everybody!
I am using the Vesc6 MKIV on a DIY Onewheel build with a Hubmotor called PHUB188. Sadly I cant enjoy the build cause the Vesc or motor is acting weird
You will find a link to my screenrecording from the Vesctool app here: https://drive.google.com/file/d/1zzUDhVAo0wAqm7aOa0zqpb0LGClon9VN/view?u...
I am currently using the Vesctool beta 5.02
I did use the FOC wizard many times, the motor operates fine when i set the Motor Current max to 45A or below, however 45A is not enough to properly balance someone when accelerating or going up a hill.
Battery Max is : 50A also -50A
Absolute Motor Max is : 120A
I hope someone can help me
Cheers Adrian
mds1274
Is this a sensored motor? I'm not sure if I can assist but knowing a bit more about the hall sensor could help.
