battery settings in VESC with lion charge only
rageagthemhcn
rageagthemhcn's picture
Hi I'm hoping someone can give me a little information regarding running a setup with a 12s4p 21700 molicel charge only BMS...I'm not sure exactly what the dangers of running the lion pack without discharge BMS and since i'm using a VESC esc can I protect my battery through the esc in the vesc tool settings and if so PLEASE what settings do I need to focus on!
What do you mean Charge Only BMS?
You can set up low voltage cutouts and max current limits on the VESC to protect your battery.
