e-bike vesc6 too high erpms?
artteth
artteth's picture
Last seen: 2 years 4 weeks ago
hi
trying to setup vesc 6 on my e bike
i use this motor https://www.hacker-motor-shop.com/Brushless-Motors/Hacker-Q80/Q80-8M-V2.htm?shop=hacker_e&SessionId=&a=article&ProdNr=37418021&p=2986
12slipo
in foc mode have next problem
on high erpms motor starts "shaking"
i make all autodetects
under load same thing
here is video
https://www.youtube.com/watch?v=6S78Ys9n-u4
current control mode
on the video we can see that current starts osciliating on around 70-80% of erpms
max erpms on 12s motor can go is almost 120 000 and i set max erpm to 140 000
how to solve problem or what i need to try (some settings in foc tab?)
thanks
(starts from 0 is super without halls)
and some faults codes (but it only current abs because current starts ostiliating and go out of range )
Last seen: 2 days 17 hours ago
That's quite a lot of motor ERPM. Over 100k needs a bit of parameter tweaking on some motors. One thing you can try is doubling the observer gain and see if it makes any difference. You can also increase the FOC switching frequency to 25 kHz and make sure that sample in V0 and V7 is enabled.
artteth
artteth's picture
thanks benjamin
will try it all and will make video
and its problems in bldc mode if i push 100%throttle (up to 80%all ok) too(but hard to represent on the bench but i will try and will make video)
