E-Bike Throttle connect with Regenerative Braking
E-Toxx
Last seen: 12 months 12 hours ago
Hey
Need some advice to hook up an additional switch to my excisting Setup to activate regenerative Braking.
Would like to connect an switch OR reedcontact to my Magura Hydraulic Brake so that if i touch the brake can use the thump throttle for motor brake.
Actually connected is a 3-Wire Thump throttle To COMM with VCC-GND-ADC1
The switch is actually also 3-Wire...
http://www.e-toxx.com/2017/09/09/e-bike/
Does it needs also VCC-GND and ADC2 ?
Thanks in Advance
Regards
Jens
Last seen: 5 hours 50 min ago
For the CURRENT_NOREV_BRAKE_BUTTON mode the switch should be connected between RX and GND. I'm not sure why your switch has three wires though, maybe it works both as NC and NO. You can test the switch with a multimeter and see if some pair of the wires get connected or disconnected when you press it. Whether it gets disconnected when you press (NC) or connected (NO) does not matter as there is an invert option for the switch in the configuration.
E-Toxx
Hi Benjamin,
thanks for super fast reply.
Okay so if go with a 2-wire switch its just connected between RX and GND...
Ordered this one now :
http://www.i-e-e.info/universal-bremssensor-beruehrungslos-f-elektromobi...
Should be easy
Thx again
Noira
Hi, I cant configure my rege breaking. Tx to GND is keeping actual trhottle but RX to GND doesnot brake even i set breaking -16Amp (battery is 16Ah)
Can you please share screen from BLDC tool how to set it ?
Thx
Jacki Villis
Hi,m im having trouble converting the bluetooth skatebourd throttle too and ebike  throttle can someone help me program it.
