New to electric skateboards - Can't seem to get FSESC set up properly
iguanahotsauce
Hi Everyone,
I recently purchased everything I needed to build my own electric longboard and it turned out to be much more of an undertaking than I expected.
I purchased two Flipsky 6354 190KV motors, a Flipsky 4.2 dual FSESC, a Flipsky VX1 remote, and a 10S4P 10.8 Ah Lithium Ion Battery.
The pulley I have on the wheels is 36 teeth and the pulley I have on the motors is 15 teeth.
My issue has been with correctly setting up the FSESC, I've watched several tutorial videos and I've read through other forum posts but I just can't seem to get it right.
I plug in one of the VESCs and run the motor config and the motor type was set to FOC with the sensor port mode of Hall Sensors. I had everything set up and I had the motors spinning in the correct direction but when I took it out for a test ride I was only able to hit a max speed of 15mph and when I was going full throttle the VESC would cut out and I would start to coast.
I'm pretty lost here and I really want to get my board up and running and any help or advice on how to set up the FSESC would be awesome.
transcendStaticMode
Why didn't you respond to the people trying to help you on Reddit?
