how to run two bldc motor in different direction over bluetooth uart data
Raja Sharma
Last seen: 6 years 4 days ago
i am using two vesc4.12 connected over CAN and with master i connected bluetooth. i want to rotate both motor in different direction.
when i send 255  at  x and y value. both go forward , and on 0(zero) both go backward but when i send 255 on x and 0 on y in that case also rotate in same direction.
can anyone plese tell to rotate both motor in different direction what data should i send and what setting should i do
complete data format which i am sending over bluetooth.{2,11,35,255,255,0,0,0,0,0,0,0,0,51,185,3}
Yuu can invert the direction of one motor if needed. Go to Motor configuration >> General >> General >> Invert Motor Direction
