Weird Inductance measurement
a.dahhak
Last seen: 12 months 2 days ago
Hi guys,
I have an inductance measurement issue with my motor, It doesn't allow me to use HFI.
When I use a ready to run motor from T-motor everything seems fine, but when I try to mount my own motor (stator and rotor hooping), my measured inductance is different from a Dcy to another (picture below)
My motor runs fine at no load, but whenever there is a load it's struggling. Any help please ?
marc426
Hi Everyone,
I'm also working on this very project.
Any leads as to why HFI seems to be completely wrong on this even though the Ld/Lq difference is quite high (which AFAIK is the criteria for a good HFI position estimation)?
We're using an official VESC6 so we're not worried of a hardware problem...
Best,
Marc
alexshen2012
I met exactly the same question, the inductance result shows quite different each time measured. So, have you find the reason?
BR,
Alex
e-biker
I'm getting similar results, while resistance is pretty stable between measurements, inductance is jumping a lot. HFI isn't working as well, despite big lq-ld difference. Tried changing filtration in hardware, increasing sample number in measurements with no luck for better results.
Measurements with older firmware (3.62) is really stable, so i doubt its hardware issue. Hardware is custom, based on HW60mk1.
Have tested few different motors (QS3T, MXUS) and results are the same. Let me know if someone finds a solution.
Martin.
masifsr
Did you guys manage to resolve this in anyway. Facing a similar issue here with HW410 and firmware (5.03)
MohammadAsif
alexshen2012
Up
Anyone who find the solution?
BR,
Alex
Gatze
Above is spam, but I also have the same problem, despite the fact it should be quite doable with my hub motor.
emntz
Same problem here, using a motor that has a significant load from the attached bearing and cannot get a consistent inductance measurement or any meaningful information from HFI plotting.
Elizabeth Mountz
