Reverse safety function
rich
I would love to go reverse with my MTB but I'm afraid because I've read several times about people where one or both wheels were spinning reverse when hard braking. If it's possible to set an ERPM limit where above the limit the reverse function is not working, that would be great! For me reverse function only makes sense from standstill. Also it shouldn't happen that when you brake to a standstill and keep on holding the brake that it starts going reverse (that happened to me), so maybe would be also nice to have to double or triple tap the brake until it spins reverse.
Last seen: 1 day 19 hours ago
Sounds like a good idea and fairly easy to implement. I have put it on my todo list and will have a look hopefully this weekend.
This is a TODO list that I have added in the documentation.
http://vesc-project.com/node/110
rich
Thanks a lot benjamin, that would be awesome!
