Question about COMM_GET_IMU_DATA packet
rrzaripov
Hi, I  was write small Python binding for communicate with device using serial port.
As start point I use yours project. Currently I successfully handle COMM_FW_VERSION:
VESC Firmware Version 3.65, Hardware: 60, UUID: 25 00 2e 00 17 47 37 33 38 33 32 38
Now I parse COMM_GET_IMU_DATA and I have next questions:
1. Can you please explain, what mean byte before CRC value?
02 - type
43 - len (67)
41 ff - mask
ff be 74 71 - roll
03 bd 70 7e - pitch
21 40 03 26 - yaw
8c 3d 76 00 - accX
00 3e 77 00 - accY
00 3f 7e 60 - accZ
00 bf ab e0 - gyroX
00 00 00 00 - gyroY
00 3f 9c 40 - gyroZ
00 bf 96 00 - magX
00 42 0c a0 - magY
00 41 a8 c0 - magZ
00 3f 04 bc - q0
46 3d 17 38 - q1
c6 bd ef 4b - q2
d7 bf 58 a4 - q3
0c  <--- what this?
92 7c - crc
03 - end byte
2. I see that YAW values changes from 180 to -​180, and then start again from 180. Device stay without movement, why YAW changing? Possibly I must previously to set up device by sending some commands? I've stuck with this, but I see that in vesc-tool YAW not drifed.
roll: -3.719266  pitch: -2.816149  yaw: 0.016336
roll: -3.756796  pitch: -2.715678  yaw: -0.259613
roll: -3.762160  pitch: -2.892427  yaw: -179.967944
roll: -3.813403  pitch: -2.757731  yaw: 179.755348
Many thanks in advance for any help and advice.
NATUITION
NATUITION's picture
Hey,
Up for this topic, any ideas guys?
Cyril ROUDOT
www.natuition.com
Bela
Answer from vesc begins with 02 +length byte+command in this case 0x41+ mask 0xFFFF and +data + two byte 0xcrc+ 03...
In yours example 02 43 41 ff ff  be 74 ...
                         type len comm mask
Addy
Last seen: 11 months 18 hours ago
I don't have the answer to your question, but did you hear of the PyVESC project? https://github.com/LiamBindle/PyVESC
It doesn't have the COMM_GET_IMU_DATA packet implemented yet, but the framework is there. If someone implements this packet it could be merged into PyVESC.
