Cruise Control button no longer working
Jobbel
I just updated my HW4.12 to the latest firmware.
This, as well as the wizard aided setup worked flawlessly.
However i can't seem to get the cruise Control Button, which I connected to the PPM input of the esc to work again.
I am using the Current no reverse Brake Center mode.
Do I Maybe have to connect the cruise control button to another pin on the 4.12 ?
Keep up the good work
Jobbel
So i found a fix this morning,
All I had to do was to switch the Appt to be used to ADC + UART
Now the cruise control pin is mapped the right way again
