Add another motor temperature sensor type (only minor tweak needed)
Henque19
TLDR: Please add sensor type "PTC 1K at 25oC" to the list of motor senors. Same as "PTC 1K at 100oC", but as name implies: 1Kohm resistance at 25 degrees instead of 100 degrees.
More details: My motor temp sensor is a "KTY-83". The "KTY-84" is supported, so only a very minor change to firmware is needed (the KTY-83 is mentioned in "mc_interface.c", but not used as far as I can tell). I've hade a look in the code, there is a function called "PTC_TEMP_MOTOR" defined in "hwconf/hw.h":
#define PTC_TEMP_MOTOR(res, con, tbase)			(((NTC_RES_MOTOR(ADC_Value[ADC_IND_TEMP_MOTOR]) - res) / res) * 100 / con + tbase)
The "tbase" parameter seems to be the base temperature that would be 25 degrees in my case. So to add this feature, it seems a new case in "mc_interface.c" is needed (as below) and an added element in the VESC tool.
	UTILS_LP_FAST(m_temp_fet, NTC_TEMP(ADC_IND_TEMP_MOS), 0.1);
	switch(conf->m_motor_temp_sens_type) {
	case TEMP_SENSOR_NTC_10K_25C:
		UTILS_LP_FAST(m_temp_motor, NTC_TEMP_MOTOR(conf->m_ntc_motor_beta), 0.1);
		break;
	case TEMP_SENSOR_PTC_1K_100C:
			float temp = PTC_TEMP_MOTOR(1000.0, conf->m_ptc_motor_coeff, 100);
                	if (UTILS_IS_NAN(temp) || UTILS_IS_INF(temp) || temp > 600.0) {
                        	temp = 180.0;
                	UTILS_LP_FAST(m_temp_motor, temp, 0.1);
		break;
	case TEMP_SENSOR_PTC_1K_25C:
			float temp = PTC_TEMP_MOTOR(1000.0, conf->m_ptc_motor_coeff, 25);
                        	temp = 180.0;
		break;
I hope this is a minor feature that is relatively simple to implement. Thanks for all the awesome work you do, the latest position tracking at zero speed is black magic!
Henque19
It seems that the KTY-83 sensor has been added in the latest update, awesome! Thank you so much!!
